Dakota98
Jul 07, 2015Explorer
I did some searching also & it appears depending on what web site you visit, it indicates that they are primarily a starting battery but can be used in deep cycle applications.
I did see them rated at about 70Ah, which isn't very much.
You'll use about 35 amps a day just running the frig & sensors, nothing else. that would drain the battery to 50% SOC & would need re-charging at that point
If you're always connected to shore power, it will work, otherwise replace it.
Also, if the TT doesn't already have a battery disconnect switch, I highly encourage you to install one.
44,026 PostsLatest Activity: Feb 24, 2025
