Desert1667
Oct 21, 2012Explorer
Jaxom wrote:Desert1667 wrote:
I have read on some other forums that some aftermarket aluminum wheels for GM's have a little more offset, I don't know if it would be enough to make a difference. Every little bit would help. 5.00 inch to 5.350 would amount to almost 3/8 inch , might be enough to make the difference.
Desert
I think the total spacing would be 7/10ths of an inch. You would combine the two 0.350 backspacings to equal 0.700. That's close to 3/4". 3/4" is about what I have on my 2010 Dodge 3500 Dually.
Not really because if you purchase a set of 4 aluminum wheels for your GM (2 Front and 2 rear) you are only gaining the offset on the outer rear which is about 3/8" roughly. The 5" offset steel wheel still remains on the inside.
Desert
