Yosemite_Sam1's avatar
Jun 01, 2020
New on tandem axle trailer.
Is it normal that when doing a right backing maneuver the right. rear wheel of the trailer goes askew -- toe in, it appears?
Trailer is new and I recently checked the torque of the lug nuts are in order.
I'll appreciate any info.
  • Like anything, there are specifications and limits for suspension twisting and turning. Bolts could be loose. Bushings may be missing. Just two possible problem areas. I would do some measuring and talk to the service department of your new trailer rather that ignore it because someone on the Internet said it was okay. I have seen that on our tandem axle dump trucks when the suspension was shot.
  • Old-Biscuit wrote:
    yes.....tight manuvering will cause one or other tire to 'slide' which can torque the suspension.
    Normal.
    When you pull forward wheels will straighten out
    Thanks, that's very reassuring.
    I appreciate it.
  • yes.....tight manuvering will cause one or other tire to 'slide' which can torque the suspension.
    Normal.
