I totally disagree on it being normal. Unless you have one of the versions that had a BAL frame for a short period last year, the frame has a "fabricated" I-beam that is made from 3 pieces of 1/8" mild sheet steel welded together that *looks* like an I-beam. These have excessive flex in them. Compounding that is the lack of any reinforcement where the spring hangers attach to the I-beam and the fact that the spring hangers are 6" tall versus 4" tall ones. The taller spring hanger brackets cause greater leverage force on them side to side when turning, especially in tight turns. When the spring hanger moves left or right at the bottom, it also causes the axle tube to bend and cause a change in the camber. The camber change is not good for tires. Everytime you turn a corner this is going to happen. This will also happen to a lesser degree when travelling in a straight line when the weight of the TT gets shifted left/right from lane changes, swerving, etc.
When doing a tight turn, because the axles have different turning radii, one set of tires is essentially dragged across the road surface. The lateral (sideways) force on one axle causes the spring hangers to bend. And yes, they can move in the order of 1 1/2" or so.
Without getting into a lot of details, eventually you will get fatigue cracks in the vertical web of the I-beam right above where the spring hangers attach to the I-beam. You should periodically inspect your frame. Cracks can be hard to see at first.
It would be a good idea to add gussets to the I-beams where the spring hangers are. Any competent frame shop can do this. Adding a longitudinal length of 2x2 tubing to the underside of the I-beams from the front hanger to the rear one (ie, under all 3) will help too. Another thing that helps is to tie the bottom of the spring hangers together from the left to right side of the frame with a cross-member. Mor/Ryde makes one or you can make your own. Adding shock absorbers will help to reduce vertical frame movement and reduce the risk of damage to the superstructure. You might consider installing higher rated axles.
I've seen these flexible I-beams on 5 or 6 other makes and models and it's not unique to your make. The vast majority of frames have a forged I-beam which is much stronger. If you have a camcorder, lash it to the underside of the frame and watch what happens to the spring hangers when you tow it somewhere.
Here's a few pics to show what happens. Pic 1 is a 90 degree turn in a CG. Pic two is at a frame shop and they pushed on the trailer sideways with a forklift. Pic 3 shows what happens to the bottom of the frame caused by spring hanger movement. This is on a fairly new trailer. Pic 4 shows damage that can occur to the superstructure from vertical frame flex and is a separated weld in the aluminum framing.
