Oasisbob's avatar
Oasisbob
NEW OVEN ?
The oven in our R Vision Bantam Trail Lite will no longer heat up and I have learned that the part I need is no longer available. Thanks Atwood for the great customer support. NOT Anyway we use our oven most every trip so need to replace it with a used unit. My question is about size. Are they universal or does size vary? BTW there is no thermacouple on this model. The knob controller valve is faulty.
  • The oven in question is
    ATWOOD
    MODEL# R-A1731W2P
    SERIAL# A08020077
    I will call Laurelhurst today. Thanks for the suggestion. I was told by Etrailers and a local trailer shop Atwood no longer supports this model.
  • Hi Bob,
    Generally speaking from what I have seen there are two sizes of RV ovens, small and smaller. You neex to pull your old one out and measure the cutout. If you have the smaller one, you might check and see if you can cut a bit and get the small one in.
  • Have you tried calling Laurelhurst distributors in Portland?
    Make and model of range/oven?
