lawrosa
Mar 13, 2018Explorer
Thats like a 50 amp hour battery. If your plugged int camgrounds not an issue. If you want to do camping off the grid watch your power use. That battery will not last long.
Its hooked up correctly..
As ststed for 120v you need to be plugged in...
I would not even entertain the though of adding an inverter with that battery..
If anything get the small plug in types and add 12 volt outlets to the TV area or other places where you need them..
I ran two of these in my old camper. One for the TV and one for a box fan and phone charging...
Small 120 watt jobs will serve you well. I used this one. No fan noise. I ran 100watts through them easy...
