SoundGuy
Mar 15, 2018Explorer
aftermath wrote:
When you hear "don't discharge your batteries below 50%" I don't think many know what that means. Look at the chart and a 50% discharge will take you down to 12 volts which makes no sense what so ever.
Why does it "make no sense"? :h Full depletion of any 12 volt deep cycle battery occurs @ 10.5 volts, 50% is just a general guide for the masses, nothing wrong with drawing the battery / batteries down further as long as you don't do it too often and recharge ASAP. This general recommendation also applies more particularly to flooded batteries but with more & more starting to use other types such as AGM, GEL, lithium, etc, this general rule of thumb is also becoming less so. For the average user though it's still a reasonable guideline to follow if you expect to get any life out of your RV battery.
