Skidus1
Oct 18, 2014Explorer
To help you with the PDI, I had to take my trailer in for a couple of issues. Check all the braces on the skirting, I think they over torqued the bolts that connect the skirt braces to the frame. Check the clearance lights, I had a couple that seemed to be loose from the body so I had them tighten and caulk. Check the ground wires behind the stairs, when I got mine home there were 2 of 3 wires not connected to the frame as they had over tightened the bolts and sheared the heads off. Shower door was a little bit bowed in the center from I think being out of adjustment. Last is check all the windows in the trailer from the outside and inside. I had one window in the bunkhouse driver side where either they had made the cut out too big or the window had dropped in transit and it had a 1/8 in gap where water could have came in. My dealer fixed all issues including loosening the window and pushing it up and resealing - just something to check on when you do the PDI. Luckily my step son told me he saw light coming in when he was in the bunkhouse and it saved me from future water intrusion. Any questions, send me a PM. It's a great trailer and we are having a great time in it. Hope it works for you.
44,066 PostsLatest Activity: Apr 10, 2026
