SplinterFL
Jul 10, 2014Explorer
New Owner/Old 16ft Aerolite - Repair Project
I'm a new owner to the RV world, though have been on several trips with the inlaws these past few years in their 21' motorhome.
I just bought this little TT, one which needs a lot of TLC for a song.
1996 Aerolite 16RK, 16ft, 18 years of Florida sunlight....
It has some roof/water damage, so I started stripping the plywood and replacing.
So I'll prob be lurking while I work on getting the TT back to a decent shape.
Mods: I'm debating on putting in a 3rd brake light and turn indicators on the sides... I hate when people drive in blind spots. And a backup camera so I can easily see where I'm going when parking it. And changing all the lighting in/out to LED for power conservation. (no generator). Maybe put a solor panel on later and really debating on putting some large brushless computer fans for the vents caps and fridge coil. (save power, improve eff.)
Couple q's. I have a 1 ton quad cab (dakota slt) I use for pulling (6k limit, 2k trailer) and want to put in a brake controller... I hear Prodogy is nice... I actually returned a unit after I got it when I saw it was time-based in the fine print.
Someone mentioned about activing the trailer breaks as semi's pass to give a little drag and avoid a sway chance... is that a button on the controller or do they tap the breaks, or a seperate button/lever. (I could easily add a button to the trucks stearing wheel to put a few volts on the breaks, or a proximity sensor when something tall passes.)
It's been raining every single day (it's covered and protected), so I haven't had time to finish cutting the new wood panels down to size and glue them down to the frame and insulation. I'm thinking of OVER-LAPPING the roof panels to create a 1/4" ridge down the middle (front to back) to help shed water. Since the AC is directly in the middle, it' will have a seal issue, so I was thinking of some 1" high-density foam gasket for doors to make the seal between the roof and unit. (there were a lot of leaves under the old AC. I'd like to create a barrier so that can't happen again.)
