Dodgemahal
Dec 07, 2021Explorer III
3 tons wrote:Kayteg1 wrote:3 tons wrote:
Switch off the onboard converter-charger at the breaker - Honda cant handle both loads simultaneously…
3 tons
Inverter/charger should automatically switch to battery power when generator voltage drops.
Some of them also can be programmed to max W draw from the shore power, what will be even better.
You program 2000W max draw and inverter/charger does the rest.
OP never mentioned an inverter-charger…
3 tons
I had to go back to my first post to see what I wrote. As far as I know I don't have any selectable choices with this unit. But this is what I put in. I did not buy it from Battle Born.
https://battlebornbatteries.com/product/progressive-dynamics-lithium-replacement-converter-section-for-electronic-power-center-55-amp/
When I installed it, I moved the batteries to the basement under the floor. Plus changed all the 10 GA wiring to 4 GA. I had fun there.
