clev's avatar
clev
Honda EU2000i question
I have 2 EU2000's wired in parallel; one with a 30 amp, 3 prong, twist plug. I've used these for a few years and am now concerned about the power output on the 30 amp plug. I recently purchased a Surge Guard and it shows reverse polarity when I put it in line with generator. I checked the pigtail wiring and it is correct, bottom left blade positive, bottom right neutral (white), and and top 'L' ground (green). When I probed the generator plug, the output was 124 volts on the bottom left while probing either of the other 2 as ground. However, while probing the 2 grounds, it produced 60 volts. Shore power has no power on the grounding plugs. Is this normal for a generator or could there be a wiring malfunction inside the generator?
