I received my new Propride hitch and installed. The installation manual was not easy to understand. No parts description so you really had to guess what they were calling what. I got threw it. It real...
I had the same problem but found some lube on the stinger wedge helped a lot. I used the dustless lube like for a slide out. As for lifting it up to unhook, I've found that if I put a finger under the trailer tongue where it connects to the ball I can feel it raise just a little when pressure is off the stinger.
