- ShinerBockExplorer
RobertRyan wrote:
You were caught out lyingI so you cannot handle it when you are caught out. doubt you tell truth in any of your posts I pity for RoyB and the total waffle you have written above. Either your Psychotic or a paid troll
Where was I lying? :h
You specifically said their was no demand for our trucks and I said that was false and that there is demand(even though it small) with proof. How is that lying? - RoyJExplorer
I've learned that unless you absolutely agree with everything he says, he will use every possible way to prove someone wrong, while ignoring everything about the actual main point.
Yours being there's very little demand of high power USA trucks outside of North America, and mine being engine manufacturers go great extend to gain seemingly minor improvements in engine performance. - RoyJExplorer
ShinerBock wrote:
Yes, and is one of the major reason why OE's have to detune engines to meet them. However, aftermarket tuning does not. So just because the aftermarket increases power by tuning out these emissions does not mean it reduces the reliability of the engine like what was inferred earlier.
Some categories you can get away with multiple power outputs which many times the manufacturer will take advantage of by charging more for the higher power unit. Similar to what Cummins does with the 6.7L and how the regular output is 370hp/800lb-ft and the HO version is 385hp/930lb-ft. Or an even better example is the new X15 efficiency series which ranged between 400-500 hp versus the X15 performance series which ranges from 485hp to 605 hp. They are the same internally aside from injectors and turbos.
And for the sake of others on this forum ......... yes, emission absolutely dictates everything about engine design - RobertRyanExplorer
ShinerBock wrote:
RobertRyan wrote:
As I said you have a reading and comprehension problem. That is one issue the other you cherry pick what I say( similar to the issue RoyJ has with you) and Falsely misquote my posts. In other words ShinerBrock you are either a psychotic trioll or just a paid industry troll
How did I misquote you? You clearly said no demand which is false.
If you don't want me to call you out then stop lying just to **** on the US and our trucks like you normally do.
You were caught out lyingI so you cannot handle it when you are caught out. doubt you tell truth in any of your posts I pity for RoyB and the total waffle you have written above. Either your Psychotic or a paid troll - ShinerBockExplorer
RoyJ wrote:
For the hundredth time, because passing emissions is a GIVEN. You don't sell cars without doing so first.
Yes, and is one of the major reason why OE's have to detune engines to meet them. However, aftermarket tuning does not. So just because the aftermarket increases power by tuning out these emissions does not mean it reduces the reliability of the engine like what was inferred earlier.RoyJ wrote:
If you want to talk marine specs, I can go on all day. Cummins is very specific about how long each power level should be used for, and at what vessel weight, and how to prop for each weight.
Point?
Point is, Cummins can increase power output on the marine engine due to less stringent emissions requirements as they stated.RoyJ wrote:
All about longevity at a given duty cycle.
Please re watch the videos because the very people who are making these trucks says otherwise.RoyJ wrote:
And before you say it again, yes, meeting emissions is a GIVEN.
It is a given for the OE, it is not for the aftermarket tuners.RoyJ wrote:
The important part? Passing emissions as a result of LOADING. In other words, duty cycle (how much and how long an engine is loaded for).
It is not because chassis trucks, or class 8 trucks have tighter emissions. But rather, because of their higher loading, it's tougher to meet the SAME emissions.
So guess what happens if you met chassis cab emissions while making 385 hp? Surprise - the engine won't meet longevity targets!
I would advise you to read the re-read the emissions link I provided which shows their are various DIFFERENT emissions tests depending on vehicles type. They are not all the same.
Here is additional link from the EPA that further explains the DIFFERENT emissions requirements for each category.
Applicable Engine Test Procedures for Each Engine Category
RoyJ wrote:
Every power rating is based on the assumption of passing emissions, the ONLY difference is loading conditions (aka duty cycle).
There's no difference in "emissions tier" in Cat's duty cycle ratings, that's a constant factor.
It doesn't matter if CAT does not stated in their sales pamphlet, their are tiers and bins for each application and even more so there are also fleet averages as well.
Please reread the EPA link above. I believe the EPA makes the rules, not CAT.RoyJ wrote:
I also didn't mention the truck has to pass modern crash tests, have air bags, or ABS/traction control. Because they're also a GIVEN. You don't sell a vehicle without it.
Audi's SQ5 also had revised heads, pistons, and turbos, just to squeeze out 20 hp over a standard Q5. Oh, did I mention they have to do so while meeting emissions?
No, because it's a GIVEN.
I think you need to back track and re-read what this debate is about. You inferred that the power levels are mainly what they are due to reliability without "at 385 hp have nothing left to tune without hurting durability"(<--your exact words).
I, however, said the 6.7L was limited 385 hp is mostly due to emissions(which tuners do not have to abide by)and increasing power by removing these emission limitations can easily be had without reducing reliability or durability.
You then rebutted saying that power levels are what they due to durability in their duty cycle even though the Ram engineer stated that that is not the case. They are emissions limited, and removing these limitations and increasing power (to an extent) will not necessarily reduce reliability. In many cases it will actually increase reliability through less fuel dilution, not having exhaust gas rerouted into the intake, not having so many injector events due to pilot injection, lower EGT's, and so on.
That is what this is all about, I feel this needs to be stated because you seem to be changing the debate into something else.
Also, I am not sure you know how emissions load tests works. It is not a duty cycle test since they duty cycle is not known at the time of testing because the engine is not matted to a final chassis. They do not know what these trucks will be used for so it is based on GVWR and a few other things. They run the engine through the test and reduce the power output to meet the emissions restriction of each category.
Some categories you can get away with multiple power outputs which many times the manufacturer will take advantage of by charging more for the higher power unit. Similar to what Cummins does with the 6.7L and how the regular output is 370hp/800lb-ft and the HO version is 385hp/930lb-ft. Or an even better example is the new X15 efficiency series which ranged between 400-500 hp versus the X15 performance series which ranges from 485hp to 605 hp. They are the same internally aside from injectors and turbos. - MikeRPExplorerMe too!!!
- blofgrenExplorer
spoon059 wrote:
Sigh... I miss camping season...
LOL you and me both! :B - MikeRPExplorerYeah I agree. They all are very good w strengths. We know the Ram won’t win a drag race. But it will hold it own towing with the other too in some ways effortlessness compared to the other two. We’ll see how the move not to do an 8 speed Aisin effects the Ike Gauntlet results. In the end I don’t care, I got my new 2018 and I looking forward to hopefully years of use.
- RoyJExplorer
MikeRP wrote:
I was looking at those dyno numbers and I don’t think if there was a way to do a blind test, that one could tell the difference in power between the trucks.
And that's the point I was trying to make - the power among the 3 trucks are all more than sufficient.
In the end, it wasn't the power output and make or break towing capability. If GM wants to catch up (which as I said, they may not), then they need to revise their chassis.
Their current engine, as well as Ford and Ram, can handle a 35k trailer. We have to remember 400hp semi tractors have pulled over 100k lbs for decades. But the difference between them and a 3500 dually is chassis strength - a Volvo frame uses 130 ksi steel, with much higher section modulus. They can be up to 10x stronger than a pickup frame! - Me_AgainExplorer IIIHey 385/865 works well in my 2015. I do not care about 1000 ft lbs and probably 95 percent of buyers feel the same. I whole issue of more gears is not that big of a deal with diesel engines that have wide/flat torque curves.
Just go buy the truck that ones DW likes the best, you probably can not go wrong with any of the three.
BTW, word games with someone 10,000 miles away, does not add much to this thread.
44,056 PostsLatest Activity: May 04, 2014
