JiminDenver
Oct 06, 2015Explorer II
RedRocket204 wrote:JiminDenver wrote:
When you need the most power from a generator, when it's hot and you want to run a A/C is when you will find out that heat and altitude can cost you 40% of your generators output at 10,000 ft. It takes a Champion 3500/4000 to run our 13.5 A/C up there and even then the converter has to be turned off.
Do you have your generator jetted for the altitude?
I do know that jetting for altitude won't get you back all the power but it should help it run better and more efficient.
I haven't rejetted my generators yet because I don't use them. Champion has a high altitude jet but it's only rated for up to 3000 ft or so the last time I checked.
44,071 PostsLatest Activity: Aug 30, 2026
