APT wrote:
Going from a low walled trailer to a high walled trailer is significant. There is a lot more air resistance which means more power, fuel, and heat. If you want to keep that MDX, then I recommend sticking to under 3500 pounds GVWR (single axle) TT. Also, flush all the fluids and install a heavier duty transmission fluid cooler. If you want something heavier and high walled in the 5000 pound dry range, then I recommend any half ton SUV. Something with at least 6-spds in the transmission. Pick your favorite brand, but again you need the HD trans cooler.
Brand does not matter with respect to quality of construction and assembly. They are all about the same (not good). If you are handy and experienced with your prior RV, then I recommend never visiting an RV dealer for repairs/maintenance.
Historically, you will find the best prices for new RVs in the midwest. IF you are willing to drive to Ohio once to pick or NY, there are some "Wholesaler RV" dealers that offer discounts around 30% off. Check out RV Direct for example.
Thank you all for valuable feedback. I am learning a lot about TT.
APT: I already have extra transmission cooler on my MDX. But I am willing to buy new SUV that supports towing 6600-7700 lbs.
I am torn between getting TT that is supported by current MDX or just go little bigger (more room, sleeping) and buy the SUV as well. I am concerned about towing TT with tall walls. I will be getting load balancing hitch and sway control. I must say with my Starcraft low profile I hardly ever felt that I am towing a trailer.
As people have said I need to do my research on floor plans. What I can use is help on narrowing down the brands for better quality.
For me reliability is more important (I will pay more money and/or give up some features). I also hope to never see dealer after the purchase unless it's something I can't fix. I am willing to make a trip to mid-west but that means purchasing a new unit. I would hate to travel for used unit and not like it. BTW: For new unit, the one year warranty do I have to take it to original dealer or can it be serviced in my area?
