Spikeman's avatar
Spikeman
Advice on truck and camper purchase
Greetings I have been reading and learning at the Forum for the past 3 years taking notes. I finally decided to buy a truck and camper. Like many of you I face the following dilemmas off-road ability vs. style and comfort. or spending big bucks for something I may not be crazy about for years on end. Having almost ruled out a popup camper. I am considering making the following compromise decision advice and criticism please.
2019 RAM 2500 4x4 Crew Cab Tradesman 8ft box 6.4 gas Hemi
PAYLOAD 3190.00LBS Off-road package ,Anti-Spin Differential Rear Axle, Electric Shift-on-the-Fly Transfer Case LT275/70R18E OWL On/Off-Road Tires 3690 payload, Hill decent ,off-road shocks Ground clearance 8.6” Many components from the Power Wagon will be adding rear progressive Sumo Super springs Please advise?
Palomino HS750 hard side dry weight with options about 2150lbs H 8'2' W 86” FL 8'2 Solar panels 200w,2x Battery Group 24 12V AGM Battery, Tie Down Package-4 Torklift Brackets W/4 Happijac Turnbuckles & Chain, rubber bed mat. Palomino now has all aluminum frame with upgraded interior small but doable for a single man
Question how much 4 wheeling will I be capable of ? Forest roads only Burr Trail or Mogollon Rim trails like or something more extreme. Should I buy a Pop-up instead? Thanks
