JFNM wrote:
I agree, it sounds like you have a battery bank made of two batteries connected in parallel. Assuming that is correct...
Going back to your original question, the 100W panel will charge the battery bank. However; keep in mind that 100W is slightly less than 7.5 amps at 13.5 volts (minimum charging voltage) and that assumes the panel is working at 100% (they rarely do that). So, it is not a lot of charging but certainly better than nothing.
Thanks for the insights. You're right, one 100W is better than nothing. :)The new panel arrived today so I'll get it hooked up and see how everything works. We're heading out on a 6 day dry camping trip in a couple of weeks. If all goes well I may add another 100W to replace the 2nd panel.
