- LanceDuyenExplorertorqlift glow steps all the way. The best $350 I ever spent. I was very pleased to see such a quality product. I have also bought their stable loads and fast guns. So far I could not be happier with their products and this is coming from a picky person.
- jefe_4x4ExplorerIt is now dark and I wanted to see if this 'glo-step' thing was just hype or what. Yes, they actually glow an iridescent green. They're no halogen, but get you centered on the steps in the dark. No I'm not going to stay up all night and see if they're still glowing at O dark thirty.
jefe - jimh406Explorer IIII also suggest Torqlift Glow steps. They make great stuff.
- jefe_4x4ExplorerJust today I installed a new set of Torklift Glow Steps (4-steps) to my Lance 165-s. They are wider across the breach, and a deeper step, all aluminum and seem more Stable than the flimsier, narrower aluminum steps they replaced. They also come with all stainless steel fasteners, a real plus for longevity. The lag bolts i removed were rusted to about 1/2 their original size. They looked like some 3rd century artifact from the Aegean sea. I'm surprised the old steps didn't just fall off. The top U shaped attaching bracket failed on my old set.
There is a nice little cable loop to corral your steps during travel. The glow step part comes in as 2" square patch of glow tape, either side of the steps that retains some light after dark, kind of like the hands on your Dick Tracy watch. The only caveat I see is there is a space between the rear of the camper and the first step. If you miss with your foot, you could go down to de-feet in a bad way. My brother John had this problem and broke his leg doing exactly that. I'm sure we'll get used to it.
This product seems well made, with heavier bracketry where needed only, and stiffeners for the application to the camper itself. They come in a 3 , 4 , 5 step versions, so should fit a wide variety of applications. The accompanying installation instructions were so-so. None of the examples fit my application. Of course my Lance was made in 1998. So far I like the steps, but time will tell. And I'll tell you.
regards, as always, jefe - AnEv942NomadI had thought most the arms were stainless. Mine were rusting badly but it was the steel rivots going thru the aluminum step plates into the stainless. I had taken apart (drilling out remaining rivots) because a couple had broke. I had thought the arms were steel, thinking they might fail if rust continued I cleaned up-discovering they were stainless, rust was all surface from rivots.
Not to say yours might not have steel arms-and even stainless can corrode-just what I discovered. Wonder how many of these flip over steps have been discarded. - WoodGlueExplorer
44,052 PostsLatest Activity: Nov 04, 2025
