notsobigjoe wrote:
Thanks! Is the stat your showing me the same as mine? It sure looks it but the wires are thicker and mines a dual stage. If I can do this it would be great. Actually, I'll have my Hvac friend Garrett take a look at your post. I can afford that... LOL Thank you very much my friend, I'll let you know how I make out.
Yes my heater is 2 stage , same stat , your is 15btu 22btu furnace, mine because of larger area inside 5th wheel ,is a 25btu 40btu , but thermostat is the same
The wires are of different size I would guess because Lance wired yours and the wiring on mine came with the furnace , pos and neg colors of yours are red and white , mine are red and green as shown in attwoods wiring diagram , thats not going to matter , show your buddy page 13 and 15 of the second link towpro gave.
If your stat is just failing on the AC side , but works the heater a second stat is cheaper than replacing the heater to get a new stat that will operate both , just remember to turn one off and the other on or the AC will come on to lower the room temp that the heaters rising , vis versa.
If your AC is a coleman the 2 pages below are from the coleman/airxcel analog stat I put in my Lance TC , its for a AC and single stage furnace, but the make them for AC only ,the only difference I see is the low fan wire on yours is blue and they call it gray ,not going to matter. you would have to extend the yellow , small blue and green wires , add a jumper from the pin 3 -red wire on the exiting stat to the new one for 12vdc+, I dont think you need the 12vdc- except if its used for a furnace
IF you call airxcel with the model AC you have they can confirm the cool only stat you need , If its a dometic still the same sort of thing but their stat
