I currently have ST205/75R14 Trail America ST Radials 6 ply Load Range C tires on My Lance model 1985 Travel Trailer. Looking to replace all four tires, any recommendations for good quality tires ?
take your TT to a tire dealer and have them check the TT weight and add 2000 lbs to that for a tire rating. you have "c's" now and I would go to at least a 8 ply, ten ply would be a lot better. might save you from some nasty blow outs during the summer heat. and find out the air pressure to use in the new tires for the weight you are towing, check the max MPH rating for that tire also. most are 65 mph rated. be a good idea to not go over that speed.
