bobndot
Jun 08, 2018Explorer III
treesbro wrote:
The trailer has weight distribution hitch mounting brackets on it already, and I will be researching a lot to find a good quality WD hitch for the longer term. I will be upgrading the load D tires to Load E tires before I hit the road as well.
Congtats, I wish you all the best in your repair and mod adventures, please do keep us posted with pics.
Re the WD brackets, don't limit yourself to matching a hitch to use those brackets, they might be for a low end hitch.
Research them and be open to an Equal-I-zer 4 point sway hitch, Blue Ox Sway pro or Reese dual cam which are all affordable ballpark hitches that do a very good job .
Tires: upgrading the tires might change the tire size, wheel and the bolt pattern must match OEM. Make sure they fit under your TT, measure your clearance.
