Artum_Snowbird
Oct 05, 2018Explorer
Solar charging can work, but also remember when it's cloudy and cool, or even raining, you use the power but solar will not produce much.
A small generator can really help at times. Two batteries will only need less than an hour a day of generator to keep things up.
Get a battery voltage meter with two decimal places and observe the battery voltage when power usage is low. (Not while running the furnace). You will learn how long your batteries last this way.
Blocks and pads in combination can make it easier. Every so often run them out just so you know it works well.
44,068 PostsLatest Activity: Jun 10, 2026
