Takamine
Oct 05, 2018Explorer
I installed my electric tongue jack in about 10 minutes. It's a really easy install and I thought well worth it. My WD hitch requires numerous ups and downs to connect and install the bars.
You should be able to download a 2018 Ford tow capacity chart for your vehicle. As mentioned above, your capacity is dependent on engine size, cab configuration, wheel base and rear axle ratio. For mine, the rear axle ratio was a letter code that was on the door panel of the truck.
44,068 PostsLatest Activity: Jun 10, 2026
