cjhorton's avatar
cjhorton
New to Travel Trailers - Nissan Pathfinder V6 TV
Hello everyone and thank you all in advance for taking the time to give me your thoughts and advice.
To start off, I am totally new to Travel Trailers. My wife and I are having a lot of the same discussions that I'm seeing in some of the posts here but most of the posts I've read have been older than 5 years so I thought I'd throw where we are at in our thinking out there and see what a group with experience would advise.
As the Subject says we have a 2008 Nissan Pathfinder V6 4x4 which has a max tow of 6000lbs with a weight distributed hitch. We have 3 children ages 2-6 at present so our current leaning is towards two double bunks as the girls can sleep together (although triple bunk options intrigue us too). No pets to worry about though.
We spent some time looking at Hybrid/Expandables but have been leaning towards a TT that is all enclosed with no 'tents'.
I guess it boils down to a few main questions to start:
1) My understanding of what I can or should tow with my TV is limited but improving so any advice in that regard would be greatly appreciated. My current feeling is that something of a dry weight about 4200-4300 lbs should be my max. Does this make sense or can I go higher? Does it make sense to go higher?
2) We have been looking at trailers between 18 and 26 ft (without hitch). Any recommendations with this particular TV? We eventually want to upgrade to a pickup like an Ecoboost F150 but that won't likely happen for at least 4-5 years.
3) Any specific recommendations on trailers? We like Jayco Jayfeather 228, Jayco Jay Flight 23MB, Jayco Jay Flight SLX 264BHW, Lance 2185. I think that gives some idea but again, the whole weight piece has me wondering what I should do more than anything.
Again - thanks for the advice. I look forward to seeing what all your thoughts are.
Chris Horton
The Great White North, BC, Canada
  • I would "assume" that that 6000 lbs. towing would only be with the tow package. my Highlander is 5000 lbs. with one, 2,000 lbs. without.
    bumpy
  • Chris,
    First step to see what your pathfinder can tow is to look on the certification sticker on your driver's side door jamb. It will indicate the GVW, GAW, and possibly, the maximum weight of "all cargo and passengers should not exceed..". What you need to determine is the payload weight capacity of the vehicle. Just a fast search online showed the Pathfinder to have a payload capacity of 1170-1550 lbs.
    From the payload capacity, an owner works backwards subtracting the tongue weight of the trailer, the weight of the weight distributing hitch, the weight of any cargo, and the weight of the passengers. If the total falls under the payload capacity, you're within the vehicle's rated towing specs. Most folks find that they run out of payload capacity before they reach the maximum towable weight rating.
    You should also look at how Toyota equips the Pathfinder for any optional "Towing Package" (if you don't have it). Things like tranny coolers and oil coolers, better suspension, etc. They can all make a difference as to how the vehicle tows or if it has problems without those accessories.
    I have no wisdom for you about new trailers. Mine is old as the hills but has been restored. Good luck with whatever you buy and happy trails to you and the family.
