CraigJConrad
Jul 06, 2014Explorer
ARGHH! Just when I thought this was all settled, the question of rear axle ratio raised its head. My purchase order doesn't identify the rear axle ratio, but the Dodge web site notes that it comes in two different ratios. So, after digging further, I find that the V6 standard model comes with the 3.45 ratio, but upgrading to the V8 Hemi changes it to 3.09 as the group contains:
--5.7-Liter V8 HEMIĀ® MDS VVT Engine
--220-Amp Alternator
--230MM Rear Axle
--2-Speed On-Demand Transfer Case
--3.09 Rear Axle Ratio
--GVW Rating - 7,100 Pounds
--Heavy Duty Engine Cooling
So, if I understand correctly, the 3.45 is better for towing, so that would suggest I should have stayed with the V6. But the V8 is better for towing (power and weight ratings), so I should stay with the V8!!
I can still change my order for this car until Wednesday. What should I do??
Anxious all over again .... Craig
--230MM Rear Axle
