opnspaces
Jul 07, 2016Navigator III
davpratt wrote:
OP here:
On the initial campground attempt to hitch, the TV was enough out of alignment that the drivers side square bar was way off to the side, and we couldn't push it enough toward the L bracket to get it into place.
You should be able to swing the bars fairly easily. From your description it sounds like you possibly have the wrong ball and if so it can cause the bar sockets to crack and fail. Go look at the bottom of your hitch. The shank and nut of the ball has to be completely inside the hole in the bottom so the bars can swing over the hole. If the threads stick out of the hole the sockets will hit and crack on tight turns.
44,066 PostsLatest Activity: May 15, 2026
