BeerBrewer wrote:
I'm new to RVing and I'm looking for our first travel Trailer. After looking at quite a few travel trailers I've come to the conclusion that I may need to upgrade my Pick-up Truck (2006 Tundra with 57K miles on it) because it can only pull 7000 lbs (minus tongue wt) and most of the trailers we like are either out us right at that 7000 lb limit or just over. So I'm know looking for a new tow vehicle. The new GM, Ram, Ford half ton trucks (properly equipped) all claim to be able to pull over 10,000 lbs and the 3/4 ton (250 or 2500) almost all can tow more, but are A LOT more pricey.
We "think" that we'll be buying a trailer that will put in the 7000 to 8000 lbs range, well within the capability of a 1/2 ton truck.
Should I go with a 1/2 ton or 3/4 ton truck? If so is it worth the extra cost?
Should I consider a diesel or stick with a gas engine?
Thanks
There are about 2.3 million threads on this here. It's not what you can pull, it's what you can carry. Payload is what matters. Tongue weight + load in bed + passenger load. You will have 1000 lb tongue weight + the rest. Only you can do the math, and the answer will drive all your other answers.
Mike
