Goldstalker
Mar 31, 2014Explorer
81SHOVELHEAD wrote:Carhlr wrote:
Trucks payload is 1873lbs rear axle is 3:42 tongue weight of TT is 640lbs me wife and 3 kids I looked around I think I'll be right at the limit maybe just under. I drive semi for a living so pulling a Trailer isn't new just wanted to make sure I had enough truck it has trans cooler, oil cooler, tow haul mode manual push button shift if needed I guess ill find out we pick up the new TT in 2 weeks. my main concern was from tongue to end is 35 feet I see the dreaded TT sway on the highway all to often when im passing one. I hope this set up will NOT have the sway
Ask your dealer if he will up grade the WD hitch to an equalizer 4 point hitch
I did on my 2014 Cougar 28 RLS (31 FT 7500 loaded weight) & we have zero sway issues
Mike D
x2 or a Reese dual cam. Also some heavy duty tires will help a lot too. Get some load range D or E.
44,029 PostsLatest Activity: Jan 21, 2025
