alexleblanc's avatar
alexleblanc
New TV - Ecoboost F150 to 6.7 F250
So the time has come to say goodbye to my much enjoyed and much loved F150 Ecoboost, I've recently upgraded to a much larger travel trailer (close to 10k lbs loaded) and it was time to get an appropriate tow vehicle to match. I originally went in looking for a leftover 2013 F250 with the 6.2, none were available locally that came close to fitting my needs or requirements, however they had a sale that fell through on this particular truck and really wanted to move it off the lot. I came in at the right time and ended up paying 19k less than MSRP for this truck including Line-x in the bed, a Bakflip tonneau cover and the paint protection package (was applied for the original purchaser). This truck stickered for 62,300.00$ and it ended up being cheaper than a 2014 XLT 6.2 gasser they had on the lot.
My Father in law was looking for a truck and ended up buying mine for the trade in value so he got a very good deal on his end too, plus i'll still get to see it and drive it every once in a while.
Here's to 2.5 years, 19k km's of towing, 68k km's and zero problems. Great truck, would buy it again.
The new truck is an XLT with the center console, backup cam, tailgate step, remote start and 3.31 gears, otherwise its a real workhorse. The 6.7 puts out 400hp and 800lb/ft and it feels every bit as strong as those numbers suggest, specially while towing my new beast. I look forward to hitting the hills and seeing it perform. Seeing as it is a bit plain, I will be changing wheels and adding a few things, otherwise I'm very pleased with it. no more worries about payload with this setup.
Old & New
  • I wish trucks came with auto-leveling headlights. They are designed for such varying loads, and the headlights are aimed right empty from the factory, so you put a load in and you are blinding people and lighting mostly the overhead signs on the highway. My Ford is easy to adjust, I carry a 4mm socket and ratchet with me, but even so you have to either guess or stop and find a wall when it's dark to do the adjustment, then you have to remember to back it off again when you unhook. I hate that. My Dodge was hard to adjust and the adjusters would seize.
    Brian
  • Beautiful truck! I like the crew cab short bed. The truck looks level with the trailer on to me looking at the shadow. The grass line gives an optical illusion that it's down in the rear. Our 5th wheel sits our truck level too. Never was intended to ride at it's empty height.
  • VintageRacer wrote:
    Nice looking truck! Seems to sit down a bit with the trailer hitched, is that an illusion? I heard the new trucks had a bit softer springs than the older ones. They sure ride nice though!
    Brian
    yeah, it's not sitting the way I want yet, but I haven't touched a setting from where it was on the F150 - I need a new shank to make it work and i'm planning on a Propride 3p purchase this winter anyways so this setup will work fine for the next two trips.
  • Great looking combo!!! Here's hoping you have many wonderful trips in your new TV & TT.
  • Love my '13 6.7. I bet you will too, especially the first time you climb an 8% grade.
  • Nice looking truck! Seems to sit down a bit with the trailer hitched, is that an illusion? I heard the new trucks had a bit softer springs than the older ones. They sure ride nice though!
    Brian
