rjstractor
Feb 15, 2016Nomad
Grit has good points, but as a counterpoint I think you are on a good track. You're obviously mechanically inclined, and buying an older truck for cheap and going through it inch by inch seems to appeal to you. If you buy a newer truck for $10K, it's still going to be old enough to have potentially hidden gremlins. By basically rebuilding the truck from the ground up, you're going to know and address every little issue. Good luck either way.
