- krobbeExplorerWithout having actually weighed the tongue, I would calculate 13% of 4500# and add another 80# for the WDH. That comes out to 665# on the receiver. Plus any weight difference of the new receiver to the old.
What did you say the payload of the TV is? And how much weight in passengers and cargo are you planning on carrying inside or on the vehicle?
The payload limitation is the best place to start when estimating what it can tow. - horton333Explorer
Huntindog wrote:
horton333 wrote:
You said
"The OP IS new to this. The first thing he needs to know is that the tow ratings are essentially an advertising number. Few vehicles will actually be capable of that rating.". So much for accepting published numbers.
I used the published numbers, and someone else's estimate of hitch weight which seems as good as anything given no one knows the trailer to say
"The numbers say it's ok, easily actually." 7000 is larger than 4500 and 1440 carrying capacity and 800 hitch cspacity being enough for an estimated 520 vertical and leaving a reasonable margin for pasengers. When I point out the real world measurement confirms these published numbers, and in my case more, that is just adding informed observation to counter uninformed speculation about the published numbers that you assume are wrong for whatever unspecified reason.
I'd be happy to have a chat, and then little doubt a joimt chuckle, with the Magna engineers who worked on this about some comments in this thread. Hey they are just 10 minutes up the street from me.....Nah why waste people's time even if it would be so 'Annie Hallish'.
You previously said:horton333 wrote:
There are lots of people who actually have these vehicles who diassagree with your assumption, based on their experience. Yes tow ratings are largely marketing numbers on smaller vehicles, but on smaller vehicles tow ratings tend to be *less* than the vehicle is capable of: to upsell customers to the more profitable, and for many people less useful, trucks.
I would think that you as an engineer would refrain from such remarks.
Just as a professional courtesy if nothing else.
I seriously doubt that you have ANY knowledge just what went into the Mercury's engineers (or any other vehicles) methodology in arriving at the numbers.
As an engineer, I bet you want others to take your profession seriously. Yet you do not want to reciprocate, as you "know" better.
You made a broad smear, saying their specifications are fraudulent and will not be met. Your reasons for ignoring their professional abilities: unspecified. Now that seems like.....well not taking seriuosly the people who published those numbers, at the least.
It is congratulations to the people who published the specifications to observe real world experience confirms their specifications, and indeed exceeded, and can be used with confidence as I did. This congratulations on a job well done you try to spin, with thinly veiled insult once again, as me somehow not taking seriously their professional abilities?? Wow.
Anyway too much time wasted already on distraction from the subject matter. - HuntindogExplorer
As an engineer, I bet you want others to take your profession seriously. Yet you do not want to reciprocate, as you "know" better. - GrandpaKipExplorer II
horton333 wrote:
GrandpaKip wrote:
Remember that if the camper is loaded and weighs 4500 lbs., you are looking at about 520 lbs. of tongue weight. You will need to subtract that from your payload sticker and then figure out the rest of the weight in your vehicle. You may find that you are getting uncomfortably close to max payload.
Get all the numbers for all the weights and do some figuring.
Good luck.
So assuming 520# that's ~925# left for people and cargo - and of course extensive cargo should be put in the trailer anyway. What about that is that makes you 'uncomfortable'?
Nothing. It's just that you nor the OP posted a payload sticker rating fot the TV. Therefore I just mentioned the tongue weight because it is a major consideration.
I also tow with a "smaller" truck. I have weighed and reweighed many times to keep a safety margin. - horton333ExplorerYou said
I'd be happy to have a chat, and then little doubt a joimt chuckle, with the Magna engineers who worked on this about some comments in this thread. Hey they are just 10 minutes up the street from me.....Nah why waste people's time even if it would be so 'Annie Hallish'. - HuntindogExplorer
horton333 wrote:
Huntindog wrote:
horton333 wrote:
Huntindog wrote:
You have an opinion there.
Actually I gave directly relevant experience and measurement.....that is more than opinion.
Not at all. There is good experience, bad experience, and lucky experience. Doing something that one should not, and being lucky with no breakdowns (yet) or other problems can delude one into thinking that the TV is capable of more that what the engineers that designed it think.
That doesn't mean that the next person that attempts it will fare as well.
You either believe in following the numbers or you don't.
I do not have a problem with that... I do have a problem with someone recommending that a newbie ignore the numbers.
The numbers say it's ok, easily actually. Beyond that I've used a similar vehicle to pull larger and significantly larger trailers for something like 60,000 km pulling since 2003, it's not marginal. I go in all kinds of weather, never any trouble with pulling and reliability: it's over 300,000 km total now and I still think nothing of taking it out of province on a regular basis. Ya it will go in a year or two as the inside is shot, but that's not bad service. That is fact, and it's not luck and there are lots of others who have the same experience.
My background was as a design engineer for 30 years. I really don't accept these emotional replies of insult like saying I "delude" myself, I'll stick to the physics. Enough said.
As an Engineer, Would you be OK with another engineer that has NOT designed or has any detailed knowledge of just what went into one of your projects, just giving it a whirl, not having a problem , then proclaiming on the internet that you, the original Engineers numbers are too conservative? - totaldlaExplorer
GrandpaKip wrote:
With WD hitch?
Good luck. - horton333Explorer
My background was as a design engineer for 30 years. I really don't accept these emotional replies of insult like saying I "delude" myself, I'll stick to the physics. Enough said. - HuntindogExplorer
I do not have a problem with that... I do have a problem with someone recommending that a newbie ignore the numbers. - whatimmadoboutmExplorerI tow my Jayco SLX 195RB (Approx 3K lbs dry) with an '03 Explorer 4.6L. Using a weight distributing hitch, I've had no issues with stability, and have pulled the trailer in a variety of situations. My combination leaves me wanting for more power in the mountains, but it's definitely manageable if you are reasonable about speed, and accept the fact that the engine will be revving higher during any sort of uphill grade.
44,054 PostsLatest Activity: Dec 18, 2025
