Grandpere
Aug 02, 2014Explorer
sandra67 wrote:
New to forums, hope my inquiry isn't a pain. My head is spinning from trying to calculate GCWR, GVW, GVWR, etc. Have been researching for weeks. Hoping someone could just answer my question. Have not bought rig yet. If I have a 04 GMC 2500HD Allison or similar, what would be the max dry weight 5th I can buy (example, 6,680-10,600 lbs.) It seems if I get a single slide this truck is ok, but if I go to a double or triple slides I need a diesel? Don't really want to get a diesel. Solo female planning to head out next year. Thanks for any advice.
1st off welcome to the forum. GVW & GVWR are the same thing, Gross Vehicle weight rating. This is the weight of the vehicle with fuel, passengers and cargo. GCVW is Gross Combined Vehicle weight rating. This means the combined weight of the tow vehicle and the 5er.
Do yourself a favor and purchase a 3500 or F350 truck. It is way too easy to over load a 2500 or F250 with a 5er, because the weight of the 5er goes up quickly with the addition of propane, water, dishes, clothes, and everything else you will put into the trailer plus the weight of the trailer itself.
As for gas or diesel, it is a toss up. The expense of the diesel fuel and the extra costs of maintenance compared to the cost of gasoline, decreased mileage and lesser maintenance costs about balances out. If you prefer to drive a gasoline outfit then go ahead and get a gasoline powered vehicle. The only real benefit to a diesel is the pulling power. A diesel will pull hills easier than a gasoline outfit.
44,056 PostsLatest Activity: May 04, 2014
