RoyB
May 29, 2013Explorer III
Any trailer made in the early 2000's is going to be hard to find info on. I would go to google and enter your YR and Model number and keep searching. Anything interesting you find copy it and move to a folder on your computer.
I did find a pretty good listing of a similar trailer with some info you might need. Most finding usually just include maybe one photo and a very brief description. Definitely copy this info to a folder on your computer. Go to the other listing here and capture all of the different interior photos of similar years. Eventually you will have pretty good photo package of your trailer. They will not vary much from year to year.
2002 Rockwood Freedom Model 1610
Rockwood Tent Camping Trailer Model 1610
GVWR (Gross Vehicle Weight Rating)
2,287 lbs. (1037 kg)
Base/Dry Unit Weight
1,574 lbs. (714 kg)
Base/Dry Hitch Weight
187 lbs. (85 kg)
Base/Dry Axle Weight
1,387 lbs. (629 kg)
Cargo Capacity
525 lbs. (238 kg)
Box Size
8 ft. (2.44 m)
Trailer Size (Closed)- Includes Hitch
14 ft. (4.27 m)
Height (Closed)
57 in. (1.45 m)
Trailer Length (Open)
17 ft. (5.18 m)
Interior Height (Open)
6 ft. 6 in. (1.98 m)
Travel Width
85 in. (2.16 m)
Tire Size
12 in. (30 cm)
Power Converter with Charger
25 AMPS
I notice POPUPPORTAL only has two manuals listed for download for a ROOKWOOD trailer. The 2004 manual should be ok for your trailer. My startcraft manuals included electrical diagram but unfortunately the ROCKWOOD manuals don't show one. POPUPPORTAL is a great place to read about your trailer however... Lots of input there for the older trailers...
Roy Ken
1,574 lbs. (714 kg)
187 lbs. (85 kg)
1,387 lbs. (629 kg)
Cargo Capacity
525 lbs. (238 kg)
Box Size
8 ft. (2.44 m)
14 ft. (4.27 m)
Height (Closed)
57 in. (1.45 m)
17 ft. (5.18 m)
Travel Width
85 in. (2.16 m)
Tire Size
12 in. (30 cm)
25 AMPS
Roy Ken
