bobndot
Dec 29, 2017Explorer III
Reading this thread again. Being that they skipped the SB , I would check the equalizer bars that the dealer gave to you , to make sure they are large enough to handle your tongue weight.
I would think you'll need 1200 lb bars or more, maybe 1400's ?
Be careful how much stuff you load into that TT floorplan. The underbed/pass thru storage areas will add to your TW.
I question the trucks axle ratio as well as payload towing a large 34/35 ft with a 150 with 3.31 gears. I would get some opinions from Ford owners towing a TT that size and weight. Hopefully, im wrong .
is this your TT ?
New 2018 Forest River RV Wildwood Heritage Glen 272RL
Sleeps
Hitch Weight 845 lbs
Dry Weight 7294 lbs
Cargo Weight 2351 lbs
Fresh Water Capacity 54 gals
is this your TT ?
Sleeps
Dry Weight 7294 lbs
44,056 PostsLatest Activity: Jul 04, 2013
