krobbe
Mar 29, 2015Explorer
I'm not understanding your troubleshooting method. It seems as if you are interchangeably using terms like polarity fuses, dc fuses, voltage, current, etc. In comment 2, are you reading voltage between a blue wire post that is 12vdc and a red wire post that is 120vac? There would be no benefit in doing this. If you suspect that the DC output from the converter to the battery is a problem, you should read something like 13.6 volts DC.
44,066 PostsLatest Activity: May 13, 2026
