Danoo
Aug 24, 2020Explorer
That's a bit to much trailer for your 1/2 ton. You should be looking for a trailer in the 5000 to 6000 gvwr, not 8500, thats for a 3/4 ton truck. 6000 gvwr trailer will have a 700 lb tongue weight, which is as big as you should go. Find a trailer in that weight range that has the floor plan that will work for the two of you. Good luck.
