valhalla360
Aug 25, 2020Navigator
Use the GVWR as a starting point (since you don't have the trailer, you can't weigh it and get the real wet weight).
Assume 12-15% of the GVWR is the hitch weight. Odds are that creates a limitation that will likely keep you down around 6000lb.
Finding an existing layout that gives you two dedicated workstations without taking over the dinnet and couch is problematic.
You will also have to figure out how much internet you need. If you are on lots of video calls, it becomes more problematic.
