jerem0621 wrote:
rubsal70 wrote:
Guys Merry Christmas again. Thank you all for the info that y'all have given me. As of right now it looks like I'll be changing to 3.73 gears. I also will be adding a transmission cooler to it. What else would I need. The way we camp with the family is we just take clothes, cooler and some gear. It never totals 500 lbs of cargo. Besides the cooler what else do y'all recommend. My truck is not a 4x4 so only rear axle change would be needed. I do plan on getting a WD with sway control and obviously brake control for the trailer. Do I need to upgrade brakes to my truck also? I appreciate the info. I'm a little confused but to me it makes sense that changing gears will add max tow as per manual and like others have confirmed. To the person who posted the video to me and like someone said it doesn't look stressed. Any one else have any more advice please let me know. I will try to make a decision in the next week or two
Thanks
Here is a thought... Instead of 3.73 why not go to a 4.10 now. The cost is the same and you should not notice much difference between the two in daily driving. However, towing will be much nicer with the 4.10.
Thanks
Well my truck's manual has two options under the same engine. My current 3.23 and the 3.73 gears. I thought I was only able to do 3.73. If I do 4.10 what is my max tow? Also with the 3.23 the gcwr was 10000. With the 3.73 it has 12000 gcwr. What would it be for 4.10?
