Passin_Thru
Jul 12, 2013Explorer
You may have your hands full with a Toyota Sequoia as it may be barely adequate. You need to have some kind of a lift hitch such as a Reese Dual Cam asa the dual cams are for anti sway. Check your book for towing capacity and then weigh it and the trailer by weighing each axle and then all axles added give you the Gross Weight, do this after you load up. I know someone who pulled with a Tundra and complained it was too light for towing.
As for a generator 5000 Watts and Honda or Onan as others aren't reliable or are too noisy. Even Hondas are loud.
