jerem0621
Jul 13, 2013Explorer II
mcasanovas1 wrote:
One more question. Where do I find information on what kind of adapter is needed for tow package. I think my sequoia has the 4 pin connector (adapter??). Are they standard or are there different ones?
Do not tow the travel trailer with your Sequoia yet.
You need parts... I am going to be as specific as I can...You need to buy some parts for your Sequoia. Here is what you need. NOTE: None of these links are affiliate links, I get nothing for recommending them.
Brake Control- You need this to control the breaks on the trailer. I recommend the Prodigy P2.
Prodigy P2
You will also need this to convert your 4 way flat to a 7 way AND get power to the trailer brakes (from your brake control) to your trailer brakes.
Universal Installation Kit
You will also need towing mirrors in order to remain legal. I had mirrors similar to the ones I am going to recommend before I bought my truck with built in tow mirrors.
Slip On Tow Mirrors
You will also need a Weight Distribution Hitch for your trailer and sway control. There are basically two types.. both work well when used correctly.
1) Weight Distribution with add on sway control bar. (This is what I run and prefer)
Here is the best "deal" in WD and add on sway control and its from PPL Motorhomes and includes almost everything you need to get going. What I like about this is that they include the trailer ball installed.
Pro Series 1200 lb WD hitch, with sway control
since your trailer is over 25 ft long you will need a second sway bar. Again from PPL (and for under $40.00)
Reese Pro Series Sway bar
2) WD with built in sway control. There are many but if I were to purchase one right now with a built in sway control it would be the Blue Ox Sway Pro. Its more expensive but it is a GREAT design.
Blue Ox Sway Pro
You will have to get the correct trailer hitch ball for the Blue Ox as it is not included.
The next thing I am going to recommend you do is find out if your SUV has a factory heavy duty transmission cooler. If it does not, pleas add one like This One to keep your transmission happy and in one place.
Good luck and we will help in any way that we can.
Thanks!
Jeremiah
