The_Mad_Norsky
Jul 19, 2015Explorer
finsruskw wrote:
This guy has the '07 1181 that is stamped 4540 lbs w/1 slide and a '13 1172 w/2 slides that is stamped 4144 lbs??? Would the aluminum framework on the '13 account for the lighter weight assuming the '07 has OSB framing??
Dealer says the witch from OSB to aluminum occurred around the '07-'08 timeframe.
We've been checking on getting an 1172 ourselves. Believe you've got it right on the aluminum framing. They're also using Azdel to replace the wood items, and it is a lot lighter weight.
