mikemc53's avatar
mikemc53
Explorer II
May 24, 2015
Newbie Frig Questions
These questions will be coming often and will be pretty basic and maybe even a little...unsmart.
This group of questions will involve the refrigerator and how to use it (power options, etc). We are getting a Rockwood 8329ss, which is on order. We haven't rv'd in years so I am sure that things have changed somewhat, technology wise.
Do most of you load the frig prior to leaving? If so, what powers it originally, is it the TV battery? If you do an overnight quick stop at a rest area or someplace (WalMart) that is not a real campsite do you run off propane or TT battery?
What does one need to do to change over from battery to propane as far as running the frig goes? And what about when you go to shore power - do you have to do anything to the frig to change it from propane to electric?
Probably very rudimentary questions but I am clueless. And, as I said, there will be plenty more of these to come in the near future.
Thanks gang.
  • Most of todays refrigs are automatic and will run on 110 volts when available and switch automatically to propane when unpluged fron 110 voltage . Although your refer requires 12 volts for control funtions most do not " run " on your 12 volt tt battery . You should pre-cool your refer and your food before departing if possible !
