Lynnmor wrote:
Price would be OK for a garage kept trailer, but they are rare. Since it has a few years on it, and likely stored outdoors, there will be some degradation of exterior surfaces. You need to inspect the roof, caulking and all soft parts for aging. Water intrusion is common and will destroy a trailer quickly, so check everywhere for stains and soft spots. If you find anything that is suspect, do not buy. Appliances and most everything that can be easily removed can be repaired, but rot in the roof, floor and walls should be thought of as terminal cancer.
The one thing that I don't like about that particular trailer is that it is big with small water tanks.
X1, Small tanks especially the gray tank(shower and dish water) can be negatively effecting your trips. Black should be at least 40 gallons, you can always bring extra 1 gallon plastic containers of fresh water. I always carry two 1 gallon containers of water in the shower to use to flush the toilet when you are on the road.
