Hey all...just now getting into the Travel Trailer market and wanted some recommendations. Looking to get a used trailer and have absolutely no idea if any make or model is better than the other. I'...
Once you get back into those range of years you can expect anything and everything to work or not. For something that old it's on a case by case basis. You can find some remarkable units and some that haven't seen anything running but water into them. Leaks are the #1 thing to check, once they leak from the roof or windows it becomes a lot of work to restore. Also, check running gear and tire wear. Any wear on the sides of tread will indicate a potential axle problem.
