kedmondson
Jun 19, 2020Explorer
Newbie needs tow vehicle PSI advice
New member here and picking up my new travel trailer this weekend. Looking for advice on tow vehicle tire PSI.
TV: 2010 F150 supercab 4x4
TT: Grand Design 2600RB
Tires: Toyo Open Country HT2 275/65/18 LT 10-ply max 80PSI
Here is what I've calculated so far:
TV curb weight 5530
Passengers 500 (only 3 of us 99% of the time)
WD hitch 100 (was told to include that in TV cargo weight)
Addl. est. payload 300 (at the VERY most and probably nowhere near that)
TT tongue weight 594
Total estimated truck weight 7024 (max GVWR is 7200 btw)
That comes out to 1756 load per tire.
The Toyo load chart for my tires lists 1940 as the max load at 35PSI.
That's about 200lbs per tire difference, almost a 10% cushion.
Is there any reason I would increase the PSI beyond 35? Even at 7200lbs max GVWR that's 1800 per tire, which 35PSI also covers. I wasn't sure how the WD hitch spreading out the load would affect the load weight on the tires. One thing that concerns me is that 35PSI is the baseline on the load charts so I definitely wouldn't want to fall below that. I was thinking I might go with 40-45 and watch the wear on the tires.
Thankful for any advice you can give. I went with LT tires instead of P-metric due to several recommendations from various sources, including the camper dealer service manager. I wanted a more durable tire overall even if it meant a slightly rougher ride (although so far they ride great IMO). Just want to make sure I get the PSI right with no risk of blowouts due to under-inflation. Thanks!
Kevin
TV curb weight 5530
Kevin
