colliehauler
Dec 27, 2014Explorer III
sdianel wrote:I quit using chemicals several years ago. I found that if I used plenty of water and dumped once a week order was not a problem. After I dump I fill the black tank 1/3 full with water. I use Scott tissue as well, never had a problem and my gauges on the tank still are correct. I make sure before I head home and after I dump to fill the tanks 1/3 full and let the water slosh around to clean the tank. I dump before I park the trailer. The city has a dump station less then a mile from my house at the fair grounds.
With proper maintenance using the toilet is not a problem. We use chemicals in our black tank. Camco or Aqua Chem. Some people don't use chemicals. Don't leave the valve open. Dump when the tank is over two-thirds full. Flush with water. Use toilet tissue that dissolves quickly. We use Scott that says "septic safe"
http://stephaniehenkel.hubpages.com/hub/RV-Plumbing-Tips-for-Keeping-RV-Waste-Tanks-Clean
