SoundGuy
Apr 18, 2017Explorer
lgmoreland wrote:
So what gear is best for general towing? I drive a 4x4 Ford F150 with the V6 Ecoboost
I'd assume you haven't received any replies yet because we're not sure what you mean by "2H or 4A". :h I'll take a guess that you mean 4x2 or 4x4 Auto and if that's the case there's no reason to tow in anything but 4x2 unless road conditions warrant otherwise. My current Silverado has 4x4 Auto but the only time I'd use it is if towing in heavy rain that might otherwise tend to cause aquaplaning, otherwise I always tow in 4x2. That said, you haven't indicated at all what you'd be towing - i.e. size & weight - which would determine whether you could tow in Drive without undue downshifting or whether you'd be better locking the transmission in a lower gear. We'd also need to know what axle ratio your Eco is running as well ... in other words, you haven't provided anywhere near enough information for anyone to say definitively how to best run your F150 when towing.
44,056 PostsLatest Activity: May 04, 2014
