ib516
Feb 26, 2015Explorer II
jtallon wrote:
As far as I can tell, the prep kit is basically an in-bed wiring connector, and the disconnect mounts already installed and mounted to the frame. The wiring connector is easily duplicated. I just have no idea if the pre-installed mounts are necessary, superior, or simply the same exact thing I'd get as part of an aftermarket install.
They are. Just easier. There are no issues putting a hitch in a truck that didn't have the factory prep. Mine has it, and all it consists of is the holes and corresponding plugs in the bed floor, some heavy steel under the bed to make the installation of a 5th wheel hitch a no tool affair, and the in bed 7 pin connector.
