2chiefsRus
May 28, 2016Explorer
CA Traveler wrote:
One heavy draw item at a time should be OK.
BUT Few homes actually have 20A plugs. Most likely they have a 20A circuit with multiple 15A plugs on that circuit. That means you have to share the power with whatever else is running in the house. That might be very little or it might be a significant draw.
So talk to the owner and see if you can identify a lightly loaded circuit to use and don't be surprised if you just get a blank stare.
Plus the length and size on your extension cord is a factor. The shorter and bigger the less voltage drop. Therefore buy a 10 ga 50' extension cord for under $100. Price is not a factor as you don't have CG fees.
x2 - we had a randomly occurring breaker flipping problem when plugged into a friend's garage outlet until we figured out that his freezer in the basement was on the same circuit.
44,056 PostsLatest Activity: Jan 12, 2020
