azrving
Oct 23, 2018Explorer
Get a digital multi meter as you'll need it at times. You should see about 13.2 volts when the converter is in float mode and the battery is fully charged.
When you are not plugged in the converter won't be charging the battery so the voltage will drop to about 12.6 or 12.7 when fully charged. As you use the battery the voltage will drop. For a Group 27 or similar battery you don't want to discharge much below 12.2 volts.
Get a meter and come back and people on here will guide you through it.
44,066 PostsLatest Activity: Apr 16, 2026
